Posted: 2020-07-06 12:23 AM . Last Modified: 2024-04-02 11:35 PM
As soon as user logs into DCO, error message pops out as attached screenshot.
below pasted error logs from client log:
2019-12-23 11:17:00,410 WARN [com.apc.config.impact.impl.cfg.ImpactConfigurationServiceImpl] (Model Thread 0) No such profile Default. Has com.apc.config.impact.cfg.ImpactConfigurationBootstrapper been called? Anyway, creating now.
2019-12-23 11:17:19,639 ERROR [com.apc.sma.client.Application$EclipseToLog4jLogListener] (main) Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".[org.eclipse.core.runtime]java.lang.NullPointerException
(CID:153092741)
Hi Yilai,
It might be related to client temp files, user might want to start the client with clean temp files.
Client temp files are usually location in:
(Win) C:\Users\
this folder can be deleted (or re-maned to something like 8.*_old)
after deleting or renaming the folder, user can then start the client.
Kind regards
(CID:153093104)
Hi Jef,
Although the user hasn't tested your proposed workaround, I'm sure it will fix the issue.
My question is that is it a known issue or something? What did it cause?
Yilai
(CID:153093106)
Hi Yilai,
When I was working on another/previously reported case (room opening issue), I did not experience this, and I could start the client without any problem. So I was guessing most likely this client local files (the so-called temp files) might not be updated and therefore null pointer exceptions occurring.
Kind regards
(CID:153093108)
Posted: 2020-07-06 12:24 AM . Last Modified: 2023-10-22 01:44 AM
