DCO customer web service permits removal of a customer with assets
  • DCO customer web service permits removal of a customer with assets
128
Posted: ‎2020-07-03 04:05 AM . Last Modified: ‎2024-04-08 11:46 PM
692
DCO 7.5 (any diff in DCO 8?)
I believe both deleteCustomer and synchronizeCustomer will permit the removal of a customer that still has assets assigned.  This leaves the asset <-> customer relationship in an unknown state which mandates the calling program having to check for existing customer assets before delete/synch.
Any plans to adjust this behaviour?
Would it be possible to throw an exception for any cust delete activity that attempts to remove a customer with existing assets?
Happy to raise feature request
(CID:106209245)
  • Data Center Operation
Hi Ed Tarento This is by design.
The deleteCustomer and syncrhronizeCustomer will allow deletion of customers even if they are assigned to equipment. Upon deletion a reference with the "customer identifier" is kept with the equipment. This is kept in case you deleted the customer by mistake - in which case you simply add the customer with the identifier again - and all relationships between the customer and the equipment is restored.
From a DCO point of view the equipment is in a known state - and basically can be used for other customers without any issues. (and at the same time it allows for automatic re-assignment in case of an accidental removal)
We build this for automation purposes and to allow for automatic deletion of customers with out having a human to manually start the application and remove all references to the particular customer and e.g. a row of racks in case they had terminated their contract.
Best Regards
   Anders
(CID:106209277)
Best Regards
   Anders
(CID:106209277)
Posted: ‎2020-07-03 04:05 AM . Last Modified: ‎2023-10-31 10:49 PM
