DCO certificates store
  • EcoStruxure IT forum
  • DCO certificates store
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 03:22 AM . Last Modified: ‎2024-04-08 11:59 PM
745
I had an issue with Active Directory authentication in DCO and was not able to view the related certificate (no result after clicking on the button, see screenhost)
From time to time I have to trust again the LDAPs certificate
How to permanently install the Issuing Certificate to validate?
In the server.log log file I get:
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
And how to check the installed certificates?
Yannick
(CID:106205841)
  • Data Center Operation
Replies 4
745
Hi Jannick,
If I understand correctly this is likely due to the certificate change on the authentication server itself, and then the new certificate (from the AD/LDAP server) must be updated/trusted on DCO (otherwise the AD users won't be able to log in). And concerning the last question, eg, checking the installed certificates, I will see what I can find for you, thanks.
Kind regards
(CID:106205915)
Hi Jef, I confirm, I get this message after certificate changes In fact, the server name I specified is an alias that points to some LDAP servers and from time to time the target server is modified That's why I would like to add the Public Issuing Certificate into the certificate store to trust any children certificates Best Regards, Yannick
(CID:106207286)
Hi Yannick, Many thanks for the additional comments, I had a brief talk with developers and I've been told that the certificates must be handled on the LDAP server(s). Kind regards
(CID:106207599)
Posted: ‎2020-07-03 03:22 AM . Last Modified: ‎2023-10-31 10:48 PM
