Posted: 2020-07-03 12:24 PM . Last Modified: 2024-04-08 01:57 AM
Hi team,
What is a log file in DCO which keeps the information about DCO application server users login/logout and other activity?
(CID:110793617)
HI Dmitry Togushev, thanks for posting!
You can find information on user activity in the audit log (available with change module license). You can also find information in the server log.
Kind regards,
Stine
(CID:110793791)
Kind regards,
Stine
(CID:110793791)
Hi Stine,
Where Change Audit Log file could be find in DCO?
What way to find the activity a customer without change license has?
What file of server log could be used to find DCO applicatioon users login and logout?
For example DCE use /data/logs/nbc/nbc.xml to save this information.
What event in the file has to be traced to it?
(CID:111415434)
Posted: 2020-07-03 12:25 PM . Last Modified: 2024-04-08 01:57 AM
Hi Dmitry Togushev,
You can find information on the audit log here Audit Trail Report
You can also find the information in the file server.log in the log folder. Search for: logged in/logged out and you should find it.
(CID:111415494)
Posted: 2020-07-03 12:25 PM . Last Modified: 2023-10-22 01:43 AM
