DCO additional network connections
  • DCO additional network connections
129
72
Posted: ‎2020-07-03 11:58 PM . Last Modified: ‎2024-04-05 04:44 AM
861
Hi team
I have a customer who requires their international DC team to log into DCO 8.1 but are on a different physical network. DCO is a physical server. Can the spare network ports on the server be configured for a different network address range at the Centos level to work with the DCO application ok? Would this be supported and could it work in a clustered configuration as well?
Regards
Jim Davis - NIE Melbourne AU
(CID:125212540)
  • Data Center Operation
Hi Jim Davis,
I do not see any problems for this: for configuring an additional network interface, you can use both webmin (GUI) and Linux command line (nmtui, for example).
Always glad to answer your questions.
(CID:125212760)
Hi Jim Davis,
Have you solved your problem or not?
With respect.
(CID:126159019)
Posted: ‎2020-07-03 11:58 PM . Last Modified: ‎2023-10-22 01:43 AM
