DCO Webservice client example
  • DCO Webservice client example
129
72
Posted: ‎2020-07-03 01:50 PM . Last Modified: ‎2024-04-08 01:29 AM
1383
I'm just starting to develop an application that interact to DCO via webservices.
Could you suggest me a webservice client example?
 I've found this example:
https://dcimsupport.apc.com/display/public/DCIMDEVELOPER/Tutorial+-+Accessing+web+service+Java+API+u...
Where can I download DOC webservices api?
thanks
luca
(CID:113645077)
  • Data Center Operation
Hi lucama
Thank you for your question. The section you have found is a bit outdated (I'll make sure that it is updated)
For the latest information regarding DCO 8.0 webservices take a look here:
https://dcimsupport.apc.com/display/UADCO8x/Advanced+use
This sub topic of the page above is also great - it tells you how to access the API on the DCO server as well as DCIM support, it also points to a small video tutorial:
DCO web service API
Best Regards
     Anders
(CID:114230983)
Replies 6
Hi lucama
DCO web service API
Best Regards
     Anders
(CID:114230983)
Thanks.
Where can I find some example of a java rest client?
thanks in advance
luca
(CID:114822180)
1383
I'm trying with this simple apache cxf rest client:
WebClient webClient = WebClient.create("https://, ,
,null);
WebClient path = webClient.path("/assets").accept(MediaType.APPLICATION_JSON);
Response response = path.get();
and this exception ha been raised:
Caused by: javax.net.ssl.SSLHandshakeException: SSLHandshakeException invoking https://10.4.4.32:443/assets: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
thanks
(CID:114822185)
Posted: ‎2020-07-03 01:51 PM . Last Modified: ‎2024-04-08 01:29 AM
Hi lucama
This issue happens because your DCO server is running with a self signed certificate. You can either install a signed certificate from a thrusted authority as described here:
Changing SSL certificate on the server
or add the self signed certificate to the list of trusted certificates of your JVM as this question is explaining:
http://stackoverflow.com/questions/6908948/java-sun-security-provider-certpath-suncertpathbuilderexc...
/Anders
(CID:114822276)
Thanks for your response.
I've loaded in jdk cacerts self signed certificate, and I haven't  PKIX path building failed.
But now I 've another strange  exception:
Caused by: java.io.IOException: IOException invoking https://10.4.4.32:443/api/current/assets: HTTPS hostname wrong:  should be <10.4.4.32>
Any hints?
I've tried to implement javax.net.ssl.HostnameVerifier and always return true in method verify(String hostname, SSLSession session)
but it isn't invoked
thnks in advance
(CID:114822388)
Posted: ‎2020-07-03 01:51 PM . Last Modified: ‎2023-10-22 01:42 AM
