DCO Webmin firewall configuration text limit
  • DCO Webmin firewall configuration text limit
129
72
Posted: ‎2020-07-03 03:34 AM . Last Modified: ‎2024-04-08 11:56 PM
1198
Hi All,
We have had the following query regarding firewall configuration which has been submitted to support, but wondered if anyone else here has seen the same problem and could provide advice?
Is there another mechanism of adding additional addressing other than through Webmin on DCO 7.5?
"I am trying to update the Firewall settings to add in additional addresses for SNMP and Webmin admin access using a comma separated list as stated in the documentation, however there appears to be a character limit stopping me. Have you come across this issue before and how can it be resolved?"
The text character limit is in the input field text box in the Webmin client
(CID:106206580)
  • Data Center Operation
Posted: ‎2020-07-03 03:35 AM . Last Modified: ‎2024-04-08 11:56 PM
1198
Hi David,
As you know, this has been responded off-line. I can also confirm that currently the settings for webmin allowed IP's configuration is limited to 50 characters (hard coded) - I have registered an enhancement case for this so the possibility for increasing the number could be reviewed,
Thank you.
Kind regards
(CID:106206857)
Replies 5
Hi David, Would it be possible to add some screen capture(s) illustrating the configuration page/issue, and which documentation are you referring to? it would be great to have a link to that documentation page, thanks. Kind regards
(CID:106206631)
1199
Hi David,
Thank you.
Kind regards
(CID:106206857)
Thanks Jef - I think this is now all resolved, but will let you know if there are any other issues David
(CID:106206870)
You are welcome David, thanks. Kind regards
(CID:106206901)
Posted: ‎2020-07-03 03:35 AM . Last Modified: ‎2023-10-31 10:52 PM
