Posted: 2020-07-03 01:37 PM . Last Modified: 2024-04-08 01:33 AM
Hi
Regards
Norberto Castillo
(CID:113643030)
Go to My Account(upper right corner of your screen shot, click on 'NC'), change the preferred unit.
(CID:113643118)
Is there no way to set this for every user, rather than each user having to make this change them self?
(CID:113643158)
Hi Martin,
Are you referring to have all user to use metric units by default?
If yes, the default unit selections seems to follow with the DCO NTP and language settings selected during installation (Jef Faridi, correct me if I'm wrong here).
Example, on my set up, I set English, and time to Singapore, and all users created in DCO are all defaulted to metrics units (Celcius and kg).
Chris
(CID:113643184)
Posted: 2020-07-03 01:38 PM . Last Modified: 2024-04-08 01:33 AM
It is possible to use API to set this setting for existing users.
See: https://dcimsupport.apc.com/DCOAPIdoc/#!/users/updateUser
(CID:113643189)
Posted: 2020-07-03 01:38 PM . Last Modified: 2023-10-22 01:42 AM
