Posted: 2020-07-03 03:43 AM . Last Modified: 2024-04-08 11:53 PM
Hello
Based on the barcode as an unique equipement identifier I would like to update some attributes of existing equipements in DCO with data from our external CMDB.
I know we can set/update/remove some Custom Properties with the web services CustomPropertiesWebService-v2 but is it possible to update the Name and the Serial Number fields with web services or ETL?
Best Regards,
Yannick
(CID:106207311)
Hi Yannick, yes you can use the ETL - Extract Transform Load framework to import fields such as name, serial number, make, model, IP Address, barcode, tags, any custom properties etc. Please see ETL Import database configuration_item and related tables for more details and get in touch with your sales team to get professional services engaged if needed.
(CID:106207318)
Posted: 2020-07-03 03:44 AM . Last Modified: 2024-04-08 11:53 PM
Hello All, While it is possible to export these things I understand there are restrictions (last I checked) on what can be updated/changed. Identity/Name is one of the things that cant be changed via ETL or API and I also believe the Serial Number is another. If this has changed then please let me know as my local support is saying it cant be done.
(CID:106207383)
Hi Craig, asset properties can not be changed using ETL. Properties can be imported from an external system and be seen and used on associated DCO asset.
(CID:106207449)
Posted: 2020-07-03 03:44 AM . Last Modified: 2023-10-31 10:52 PM
