DCO - UCS Manager integration - API methods and functions are in use
  • DCO - UCS Manager integration - API methods and functions are in use
129
72
Posted: ‎2020-07-03 02:48 PM . Last Modified: ‎2024-04-08 01:11 AM
1101
I would like to ask how and where can I find which API methods and functions are in use in Cisco UCS Manager integration.
The reason is that I am continously having issues with physical blade and chassis move which are not updated in DCO.
Last time here I got that information: UCS Manager integration was developed with version 3. We are using version 2 due to hardware interoperability reasons and not possible to upgrade to version 3.
I would like to understand deeper how integration works such as query blade/chassis serial number, memory size, CPU cores, etc... and which API methods and functions are applied.
If I have that information I can ask our Cisco support for commintment about is there any changes between the two major versions of API.
Thank you.
(CID:116363413)
  • Data Center Operation
Hi Mate
I went through the code and tried to compile a list of all the attributes we use:
Common attributes:
vendor
revision
model
serialNumber
id
PID
averagePower
computeBlade attributes:
slotId
chassisID
processorCount
cores
enabledCores
ciscoUUID
totalMemory
effectiveMemory
threads
capped
equipmentFanModule:
tray
equipmentIOCard:
side
fabricId
equipmentPsu:
Only common attributes are used
Hope this helps,
Niels
(CID:116364948)
Note: I found a Cisco article which cover all API XML Schema and Schema Diffs that have been published since the 1.4(3q) release until 3.1: https://communities.cisco.com/docs/DOC-36350
(CID:116363477)
Hi Mate
Common attributes:
vendor
revision
model
serialNumber
id
PID
averagePower
slotId
chassisID
processorCount
cores
enabledCores
ciscoUUID
totalMemory
effectiveMemory
threads
capped
equipmentFanModule:
tray
equipmentIOCard:
side
fabricId
equipmentPsu:
Hope this helps,
Niels
(CID:116364948)
Posted: ‎2020-07-03 02:48 PM . Last Modified: ‎2023-10-22 01:41 AM
