DCO Secure SMTP communication
  • EcoStruxure IT forum
  • DCO Secure SMTP communication
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 08:23 AM . Last Modified: ‎2024-04-08 03:53 AM
1366
Hi team
During a DCO 8.0.1 installation project, the customer has stated that they would be requiring to us secure SMTP communications. I can see the "Secure SMTP" checkbox, but what does the "Requires STARTTLS extension" involve to enable this functionality?
Regards
Jim Davis - NIE Melbourne/AU
(CID:110006039)
  • Data Center Operation
Posted: ‎2020-07-03 08:24 AM . Last Modified: ‎2024-04-08 03:53 AM
Answer provided by Sean Macey
Although port 587 doesn't mandate requiring STARTTLS, the use of port 587 became popular around the same time as the realisation that SSL/TLS encryption of communications between clients and servers was an important security and privacy issue and encryption extensions were being defined for sMTP. So shortly after port 465 was defined, it was revoked with the expectation that clients would move to using STARTTLS over port 587
The result is that in most cases, systems that offer message submission over port 587 require clients to use STARTTLS to upgrade the connection and also require a username and password to authenticate.
In short, when using STARTTLS use port 587.
(CID:110007854)
Replies 5
1366
Dear Jim,
It all depends upon the SMTP Server.
To protect SMTP communications, servers can use transport-layer security (TLS), more commonly known as SSL encryption, to provide privacy and authentication.
Some servers support SSL for SMTP communications by sending and receiving SMTP traffic through the SSL port (port 465 by default) only. However, because this requires that both the sending and receiving servers support SMTP over SSL, this solution isn't always practical.
To provide SSL security for SMTP transfers over TCP/IP, IBM® Lotus® Domino® supports the use of negotiated SSL. In a negotiated SSL scheme, the sending and receiving hosts each use the SMTP STARTTLS extension, defined in RFC 2487, to signal their readiness to negotiate an SSL connection. The receiving server displays the STARTTLS keyword in response to the sending server's EHLO command. The sending server issues the STARTTLS command to request the creation of a secure connection. After the initial TLS handshake completes successfully, the two parties proceed to set up an SSL channel between them. Both the sending and receiving server must possess SSL certificates.
For More info, please refer: https://www.ibm.com/support/knowledgecenter/SSKTMJ_8.0.1/com.ibm.help.domino.admin.doc/DOC/H_SUPPORT...
If the SMTP Server requires STARTTLS extension, then you can check the option while configuring the SMTP Server for email settings.
Please do ask the Customer's SMTP Server team to provide the following details for successful email configuration in DCO.
  • SMTP Server IP Address
  • SMTP server Port Number
  • Valid From email address
  • White list the DCO IP Address and From email address in the SMTP Server for successful email communication
  • If the SMTP Server requires an authentication to send an email, then please ask the server admin to provide those details at the time of configuration.
I hope this helps.
Bala
(CID:110006046)
Hi, I'm the client Jim is supporting. we are still having a issues with smtp connection. the server we are connecting to belongs to an ISp (Spark XTRA) via send.xtra.co.nz port 465, this server requires authentication using SSL. FYI I have tested the network and firewall correctness by configuring thunderbird email and proving that app worked, however so far I am not able to get the DCO 8.0.1 to send.
(CID:110007186)
would you be able to confirm correct actuions required in DCO and Centos in order to configure?
(CID:110007187)
(CID:110007854)
Posted: ‎2020-07-03 08:24 AM . Last Modified: ‎2023-10-22 01:40 AM
