DCO SP3 patch-Where is it visible on DCO?
  • DCO SP3 patch-Where is it visible on DCO?
126
65
Posted: ‎2020-07-03 12:30 AM . Last Modified: ‎2024-04-09 12:54 AM
981
Once a DCO SP3 patch is installed why is it not visible on the splash screen stating that DCO has been updated to SP3?
How do we ensure that the patch is installed and should be available on the DCO splash screen, except for the fact that we can run md5 checksum.
(CID:105467206)
  • Data Center Operation
979
Hi Vineet,
After performing a successful installation, start the DCO client and go to Help > About StruxtureWare Data Center Operation
Then it would be possible to see the installed/running version:
Hope this helps
Kind regards
(CID:105467228)
Replies 4
980
Hi Vineet,
Hope this helps
Kind regards
(CID:105467228)
Thanks Jef, I couldn't decode the Branch Field in the splash screen, thanks for explaining.
(CID:105467273)
You are welcome, Vineet Kind regards
(CID:105467451)
Posted: ‎2020-07-03 12:30 AM . Last Modified: ‎2023-10-31 10:52 PM
