Posted: 2020-07-03 11:31 PM . Last Modified: 2024-04-05 04:54 AM
Is it possible to read DCO Recommendations from the Rest API?
Case in point, if the estimated or the measured load of a rack is above the Design Limit, is that "violation" available through the Rest API?
(CID:125209211)
I don't think its available, unless someone can clarify?
Alternative:
Get the individual items from RESTful,
GET /assets/{asset-id}/metricsHave the other system compare it 😀
(CID:125210109)
Posted: 2020-07-03 11:31 PM . Last Modified: 2023-10-22 01:39 AM
