DCO REST API - custom properties not showing up in response
  • DCO REST API - custom properties not showing up in response
129
72
Posted: ‎2020-09-15 09:50 AM . Last Modified: ‎2022-10-19 02:08 AM
1473
I've read and understood this post: https://community.se.com/t5/EcoStruxure-IT-forum/dco-rest-api-retry-custom-properties/m-p/219173#M18... regarding how to get custom properties out of the DCO via the REST API.
However, when I use the same call (https://server/api/v8.1//assets/asset_id?include=custom_properties) against our server for an asset with custom properties I've set via the IT Advisor, the customProperties field is empty ( {} )  in the response.  I've tried using both a "curl" command line call as well as using the DCO's API doc "Try it out" feature with the same results.
Any clues as to what I'm doing wrong?  Thanks in advance.
  • DCIM Support
Captain
Posted: ‎2020-09-15 11:41 AM
1463
Hello George
Can you confirm which version of DCO you are running?
When I run a similar query I'm not having any difficulty producing asset information with custom_property data. I'm using DCO 8.3.0/8.3.2
Here's an example:
https://<ip-address>/api/v8.1/assets/aa5f81b2-2a11-47bd-a8bb-88f14e5a0d5a?include=custom_properties
Regards
Greg Sterling
Posted: ‎2020-09-15 01:41 PM
In response to gsterling
1459
I don't run the server software, but am told that the version is "EcoStruxure IT Advisor 9.0.4" - does this answer your question?
Admiral
Posted: ‎2020-09-16 03:55 AM
In response to Anonymous user
Hi George,
The rest api call:
https://<ip-address>/api/v8.1/assets/asset-ID?include=custom_properties
works for ITA 9.x as well, here is an example:
Initially I thought there might be incorrect character in your api call ( https://server/api/v8.1//assets...., the extra slash "/") but that doesn't seem to be the issue - I guess any mistyping may have resulted in some error messages.
Can you share screen captures illustrating what you are doing and what is being displayed for you (sensitive info, such as IP address recommended to be masked).
Kind regards,
