DCO Integration with BMC Remedy - Web service
  • DCO Integration with BMC Remedy - Web service
126
65
Posted: ‎2020-07-04 01:54 AM . Last Modified: ‎2024-04-05 03:59 AM
1126
Hi
El customer BBVA have contract  Web Service with  BMC Remedy enable with link login user and password
https://bbvabc.onbmc.com/rsso/start?bypass-auth=true&tenant=*&goto=https://bbvabc.onbmc.com
The FW BMC y Server Remedy  are  in  site BMC Chicago. So we have a VPN FW to FW for comunication between servers
Internal FW, External FW and DC Operation Server devices are inside the bank
We want configuration in DC Operation ver. 8.1 for BMC Remedy integration
Questions:
 Can we to do BMC Remedy integration  with the information described?
Best regards
Norberto Castillo
(CID:126176705)
  • Data Center Operation
Replies 4
1126
Hi Norberto,
As described in the following page: Configuring Remedy integration
in DCO, integration to Remedy v. 8.1 is supported (it may not work with newer version(s)).
And for the integration you would also need to enter the remedy server "host name" and "IP address". The communication port (80 and/or 443) must be open between the servers (DCO and Remedy server), eg. DCO must be able to reach the remedy server.
It is also expected that the remedy user (used for integration) has access to web services/tickets (and not sure if it can work with single sign on).
Kind regards
(CID:126177459)
Hello
when I try to test in the DCO the configuration remedy, appears an alert that says that the server is inactive.
Any suggestion about what I'm doing wrong?
regards
Caroll
(CID:131960088)
Dear Jef
Please, confirm me, if we can communicate through a video conference with Webbex to explain our problem and concern
Best regards
Norberto Castillo
(CID:126179550)
Posted: ‎2020-07-04 01:55 AM . Last Modified: ‎2023-10-22 01:38 AM
