Posted: 2020-07-02 08:21 AM . Last Modified: 2024-04-10 01:32 AM
Can DCO run on a XenServer Virtualization Software Platform? I tried this and it comes up with either a blank screen or UI configuration issue.
(CID:89555321)
(CID:89555348)
Hi Mudzimu,
It has not been tested at our end and is currently not recommend nor supported. You could try to install using alternative drivers Installing StruxureWare Data Center Operation
Using the alternative drivers will give a bigger support in terms of hardware components (which might the issue using the Xen virtual environment.
If possible please share a screenshot of the error you see on screen, this might help for further investigation.
(CID:89555413)
Posted: 2020-07-02 08:21 AM . Last Modified: 2023-10-31 10:49 PM
