Posted: 2020-07-03 01:14 PM . Last Modified: 2024-04-08 01:41 AM
I would like to export information what I can see on the popup menu when move my cursor over the cabinet at power layout:
I need the Total columns like Estimated load and Peak Power from each cabinet in a room. How can I do that?
(CID:112623841)
Posted: 2020-07-03 01:15 PM . Last Modified: 2024-04-08 01:41 AM
Hi Mate,
I think some information/data could be exported via ETL integration (External system integration through ETL , ETL Export Database ) and/or by simply generating Capacity History Reports (for Measured Peak Power, Measured Peak Power feed, Estimated Load, Estimated Load per feed).
Kind regards
(CID:113644264)
Posted: 2020-07-03 01:15 PM . Last Modified: 2023-10-22 01:37 AM
