Posted: 2020-07-02 12:57 PM . Last Modified: 2024-04-09 11:39 PM
I'm trying to install DCO on a virtual machine on VMware but I can't start the server.
"Essential services are not running on the Data Center Operation server. Reboot the node and monitor the status page in Webmin. If the problem persists, contact Technical Support."
Guillaume
(CID:97484921)
Guillaume, does your DCO server have enough free disk and memory to startup?
If you're logged into webmin, click the "system information" button like below. What do the "real memory" and "local disk space" entries display?
Many startup problems are caused by lack of disk space or insufficient memory.
Regards
Greg Sterling
(CID:97484963)
Regards
Greg Sterling
(CID:97484963)
Hi Greg,
According to Guillaume berthet feedback ,He fixed the problem creating a new virtual machine with more than 4Go.
But How to add memory on the already existing DCO system?
(CID:126162667)
Hi Greg,
The virtual machine have been created with 2Go of real memory and upgrade after to 4Go - no results.
I fixed the problem creating a new virtual machine with more than 4Go.
Thank you very much for the help.
Guillaume
(CID:97484973)
Posted: 2020-07-02 12:58 PM . Last Modified: 2023-10-31 10:49 PM
