Posted: 2020-07-04 08:58 PM . Last Modified: 2024-04-04 03:59 AM
One of our client wants to restrict DCO Database port 5432 to be Open only for certain users. please advise if this is possible?
Thanks & Regards
Shemil
(CID:132670029)
Hi Shemil,
From what I know, the normal DCO user cannot be used to login to DCO's database via 5432.
You can only connect to DCO's ETL database created, for import / export to integrate with other system, not the DCO database itself.
During the ETL database creation, you can specify the user there, as well as whitelisting which ip address can access to the ETL database.
Chris
(CID:133370465)
Posted: 2020-07-04 08:58 PM . Last Modified: 2023-10-22 01:36 AM
