DCO / Cooling / Error message
  • DCO / Cooling / Error message
129
72
Posted: ‎2020-07-03 12:53 AM . Last Modified: ‎2024-04-09 12:47 AM
897
Hi eveybody,
Picture1: cooling is ok when the "fan" is on the left or right wall.
Picture 2: Error if I move it on another wall
I works only on left and right walls.....
Any idea?
Best regards
Rocchino
(CID:105468167)
  • Data Center Operation
Replies 5
Hello Rocchino, The model believes that the back wall of the data center is not within the data center. To provide a better answer we will need a backup of your configuration to test and create recommendation to correct your configuration. I will be emailing you a box link so you may upload your backup if possible. Thank You Victor
(CID:105468235)
Hello Victor tks for your answer. I have a problem. I can't use AppBox from my Company. Security rules. I have a second room, it's a copy of the first and here I don't have the problem if I move the "fan". Best regards Rocchino
(CID:105468279)
Hi Rocchino,
Similar issue had been reported to me some time ago. For unclear reason(s), in 3D cooling plan it seemed modeling the vertical grilles on certain wall (the north wall for this room) would have generated the error/notification saying "One or more vertical grilles are placed outside of the room".
I had registered it as a software bug, so it could be included in the enhancement plans for a future version.
Kind regards
(CID:105468764)
Hi Jef.
Thanks for this answer. I have a turn around for resolving this problem.
Best regards
Rocchino
(CID:105468809)
Posted: ‎2020-07-03 12:53 AM . Last Modified: ‎2023-10-31 10:48 PM
