DCO 8.3 or ITA 9.0, set tasks completed grayed out
  • DCO 8.3 or ITA 9.0, set tasks completed grayed out
126
65
Posted: ‎2020-07-05 07:53 PM . Last Modified: ‎2024-04-03 01:24 AM
1435
Hi Team,
If you do have a workorder with multiple tasks, when the tasks are in the status not started I am able to set the tasks completed for all tasks. But when one task is set to cancelled the options to change the status for all tasks become grayed out, see screenshot below, this is not very useful when you have lots of tasks in a workorder and one task is cancelled.
Please advice
(CID:144867726)
  • Data Center Operation
1435
Hi Cees,
I think you would need to complete/change the status of each tasks first, before being able to edit the status of the workorder itself:
Kind regards
(CID:144867739)
Replies 5
1436
Hi Cees,
Kind regards
(CID:144867739)
Hi Jef,
thanks for your quick response, but when you do not cancel one task then you are able to change the status of the workorder but as soon as you change the status of 1 task to canceled then the options to change the status of the workorder to grayed out, and this is very frustrating when you have lots of tasks in a workorder.
(CID:144867743)
Hi Cees,
That's correct, when the tasks are not "touched"/modified, then it is possible to edit the work orders "tasks" (all tasks).
But when you/we modify a single task (such as canceling a task), then we need to change the status of other tasks as well. This design decision basically have been made due to the fact that there might be dependencies relations between the tasks in a work order.
Kind regards
(CID:144867753)
Hi Jef,
Ok, thx for this, I will inform customer
(CID:144867755)
Posted: ‎2020-07-05 07:54 PM . Last Modified: ‎2023-10-22 01:34 AM
