Posted: 2020-07-05 11:48 PM . Last Modified: 2024-04-02 11:48 PM
I use the TAG feature in DCO to categorize rack mount equipment for instance:
Accordingly to it I created these tags and I would like setup that tagging would be a mandatory task during a new equipment installation.
As I know it is feasible with "Custom Properties" feature. What about tagging?
(CID:152078803)
Posted: 2020-07-05 11:48 PM . Last Modified: 2024-04-02 11:47 PM
Hi Mate,
Tags can only be defined after adding the device, so there is no option to make it mandatory task during a new equipment installation. User(s) should define that after adding the device.
Kind regards
(CID:152568789)
Hi Jef,
I'm thinking on a Mandatory check box what we have in Custom Properties configuration:
How that works? If a user install any new rack mount device the mandatory checked custom property has to fill out or not?
Mate
(CID:152568843)
Hi Mate,
Following page contains detail description on Custom properties:
https://sxwhelpcenter.ecostruxureit.com/display/UADCO8x/Custom+properties
User(s) can define Custom properties any time they want to do it. If users want to model a device that may contain pre-defined Custom properties settings (such as Mandatory), users are not prevented from leaving the filed empty. The system will display a recommendation to enter data, for example some thing like this:
Kind regards
(CID:152569077)
Posted: 2020-07-05 11:48 PM . Last Modified: 2023-10-22 01:34 AM
