Share Your Feedback โ€“ Help Us Improve Search on Community!
DCO 8.2 Release Notes and What's New
Showing results forย
Did you mean:ย
  • DCO 8.2 Release Notes and What's New
129
112
72
Posted: โ€Ž2020-07-04 02:04 AM . Last Modified: โ€Ž2024-04-05 03:56 AM
1118
When can we expect Release Notes for 8.2 to be available?
I have since found What's New page so appologies for misleading title:
What is new in StruxureWare Data Center Operation 8.x
(CID:126178635)
  • Data Center Operation
Posted: โ€Ž2020-07-04 02:05 AM . Last Modified: โ€Ž2024-04-05 03:56 AM
1118
Hi Lukasz,
You can download the pdf version of the DCO 8.2 Release Notes from here:
Release notes
Kind regards
(CID:126179238)
Replies 6
Hi Lukasz,
So it seems you have found what you were looking for, and there is no issue here, right?
Thanks.
Kind regards
(CID:126178751)
Hi Jef,
I found the what's new but would still like to have release notes if available.
(CID:126179115)
Hi Lukasz Staciwo,
For example see  ๐Ÿ˜€.
(CID:126179228)
1119
Hi Lukasz,
Release notes
Kind regards
(CID:126179238)
Thank you Jef already used it ๐Ÿ˜€
(CID:126180754)
Posted: โ€Ž2020-07-04 02:05 AM . Last Modified: โ€Ž2023-10-22 01:33 AM
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
