Posted: 2020-07-04 09:05 PM . Last Modified: 2024-04-04 03:57 AM
Is it possible to create half equipment in rack ?
(for example a RAD ETX202) but with 2 equipments for the same U ?
(CID:132671293)
Hi
if the devices are shelf mounted then you can model these exactly. if the devices are in a chassis then model a chassis with 2 devices in there. if the devices are half ru each then you can only model a single device representing both or do the shelf option. shelf is best I think because you have good asset control
i hope that helps
Ed
(CID:132671302)
Hi
i hope that helps
Ed
(CID:132671302)
Hello Ed,
Thanks for your help. the devices are shelf mounted but i cann't create the equipment on the half of the bay to put two side by side on shelf
(CID:132671343)
OOOOOh it's good !
Juste in properties - mounting and tick Shelf and left or right !
It's magic 😂 Thanks Ed for pointing me in the right direction
(CID:132671345)
I works. 😀 😀
(CID:132671756)
Posted: 2020-07-04 09:06 PM . Last Modified: 2024-04-04 03:57 AM
Eddie Mou Daniel Kwong Fergus Wong
Support for half-rack via Shelf option - Thanks to our expert Ed 😀
(CID:132671677)
Posted: 2020-07-04 09:06 PM . Last Modified: 2023-10-22 01:33 AM
