DCO 8.2.2 - Integration with Active Directory (AD)
  • DCO 8.2.2 - Integration with Active Directory (AD)
129
72
Posted: ‎2020-07-04 04:02 PM . Last Modified: ‎2024-04-05 12:21 AM
1210
We are installing a new DCO 8.2.2.  When we add the AD authentication server, it does not pull in the groups.  Please advise how to resolve this, thanks.
(CID:129414037)
  • Data Center Operation
Hi Yuan Jiun,
It might be configuration related issue (assuming AD server accessible), however to understand the problem would it be possible to ask for the following data:
1- DCO server logs
2- screen capture(s) illustrating how exactly authentication server settings are configured in DCO
3- screen capture(s) (from AD server) illustrating the configuration on the AD server.  (similar to images in this guide: Setup an AD (Active Directory) Server)
I will send you an invite to my =S= box shortly, so the data can be safely shared with me (if you would), thanks.
Kind regards
(CID:134028916)
Replies 4
Hi YJ,
Do update the question based on the IT team's feedback following the example given in the link yesterday.
Chris
(CID:129414323)
Hi Chris,
We have tried the settings in the shared link, but is still getting the same error or message, see attached.
(CID:129414545)
Hi Yuan Jiun,
1- DCO server logs
Kind regards
(CID:134028916)
Posted: ‎2020-07-04 04:02 PM . Last Modified: ‎2023-10-22 01:33 AM
