Posted: 2020-07-04 02:03 PM . Last Modified: 2024-04-05 02:45 AM
I'm running on Operation 8.2.2 and using Active Directory authentication which works much more better in this version. Instead of adding accounts one by into dedicated security groups is it possible to use nested groups?
Example: GroupA is in DCO. I have GroupB and I want to add it in GroupA in Active Directory.
Members from GroupB will have access to DCO?
I tried it but did not work for me. Any idea to solve it?
(CID:128754189)
Hi Mate Fekete,
In DCO 8.2.2 Active Directory authentication we can add Group A and Group B separately its works fine with all of the members, where as adding Group B in Group A feature is not supported in this DCO version, Also you could not able to see the members of the Group B as per your scenario.
So we will raise the feature request in upcoming DCO releases.
Satish
(CID:128755946)
Posted: 2020-07-04 02:04 PM . Last Modified: 2023-10-22 01:32 AM
