DCO 8.2.12 update
  • EcoStruxure IT forum
  • DCO 8.2.12 update
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 03:46 PM . Last Modified: ‎2024-04-03 11:19 PM
1499
DCO 8.2.12 update
I tried to upgrade my DCO to 8.2.12 yesterday. But i couldn't complete the installation.
The installation stopped in the middle and this what i saw in the log:
o-1.8.19p2-14.el7_5.x86_64 193/445
Dec 31 15:24:29 ibldcopv01.weizmann.ac.il operations-upgrade[17807]: Updating : perl-IO-Socket-SSL-1.94-7.el7.noarch 194/445
Dec 31 15:24:29 ibldcopv01.weizmann.ac.il operations-upgrade[17808]: tar: ./sysstats/modules/samba/alarm: time stamp 2018-12-31 15:40:03 is 935.053805019 s in the future
Dec 31 15:24:29 ibldcopv01.weizmann.ac.il operations-upgrade[17809]: tar: ./sysstats/modules/snort/alarm: time stamp 2018-12-31 15:40:03 is 935.043574492 s in the future
(CID:137728706)
  • Data Center Operation
1498
The Best is to make a new server for DCO 8.2.12. Then take the backup from old dco server and restore it in new DCO 8.2.12. It works Perfect. I recently  done it like that . its easy and safe.
(CID:137729615)
Replies 10
Hi
It looks like the system clock is incorrect.
I'm guessing that the system clock must have drifted out of sync since last install. Usually the machine is automatically synchronised with a time server. Can you check if this has been deactivated?
(CID:137728710)
I checked the clock. It seems to be ok
(CID:137728732)
hi
from my side i'm having this issue
(CID:137728826)
Hi Eitan,
As Roland kindly mentioned it seems the system time is incorrect. I guess following options could be considered:
Correct the NTP settings via webmin, StruxureWare DC Operation > Setup
or manually correcting the time (not recommended, might result in unexpected system/data behavior)
if needed, a clean installation and then restoring the latest backup would be recommended, that may give you a reliable setup.
Kind regards
(CID:137728842)
1499
(CID:137729615)
Thanks!
(CID:137729947)
1498
I did a clean install of 8.2.12, this works well.
Only issue is that I do not see the Restore option.
Anyone know where it is "hidden"? My menu looks like this:
thank you,
Karimi Igeria
(CID:137731761)
Posted: ‎2020-07-05 03:47 PM . Last Modified: ‎2024-04-03 11:18 PM
Hi Altair,
From 8.2.12, the backup/restore feature is moved to web client, Administration > Backup and Restore
Kind regards
(CID:137731774)
Thank you, Jef.
Have a nice day.
(CID:137731799)
Posted: ‎2020-07-05 03:47 PM . Last Modified: ‎2023-10-22 01:32 AM
