DCO 8.0.1 - external system - can't edit vmware config
  • DCO 8.0.1 - external system - can't edit vmware config
129
72
Posted: ‎2020-07-03 12:46 PM . Last Modified: ‎2024-04-08 01:50 AM
1301
4 External Systems configured.  I can edit config for DCE and Cisco UCS Manager but the 2 x VMware vCenter entries throw Java exception "An error has occurred. See error log for more details.   java.lang.NullPointerException"
Attached is application.log
Cheers
(CID:111413893)
  • Data Center Operation
1301
Hi Ed,
Many thanks for providing the backup file - it seems this backup/setup dose not contain configured external systems (beside the etl export):
Furthermore, it contains only the basic "DCO" license, and a possible integration with VMware vCenter would have required an additional "Capacity" license.
Please let me know if you have questions, thanks.
PS. 8.0.4 is released now - it is recommended that all existing DCO 8.x.x customers upgrade to 8.0.4.
Kind regards
(CID:111414609)
Replies 7
Hi Ed,
Would it possible to ask for a copy of the backup file, so I can test it locally - I will send you an invite to my =S= just in case if you would share the data with me, thanks.
Kind regards
(CID:111414030)
Backup uploaded
(CID:111414350)
Thanks Ed,
I will get back to you asap,
Kind regards
(CID:111414369)
1302
Hi Ed,
Kind regards
(CID:111414609)
Posted: ‎2020-07-03 12:47 PM . Last Modified: ‎2024-04-08 01:50 AM
Thanks Jef. It's the absence of Capacity
(CID:111414815)
You are most welcome, Ed
Kind regards
(CID:111414934)
Posted: ‎2020-07-03 12:47 PM . Last Modified: ‎2023-10-22 01:30 AM
