Posted: 2020-07-03 05:52 AM . Last Modified: 2024-04-08 11:12 PM
All
I have noticed that the device and rack names do not display anymore than 10 characters. What is required to have names longer than 10 characters displayed correctly? Is there a font size setting somewhere ?
Regards
Jim
(CID:108824731)
Update:-
After changing the font size in windows control panel from 125% to 100% it allowed the device name length to increase to 15 characters. It did mean however, that everything else in windows is smaller too. Would be nicer if DCO was able to control its font size...
Regards
Jim
(CID:108824738)
Jim Davis you answered your questions yourself! I can only add that desktop client always uses OS settings and scales font proportionally. You could also change OS font to some more compact, for example "Arial Narrow" or "MS PGothic". I think by default Windows is using "Verdana", which is fairly broad font. Regarding the font customisation, you could do that only in Web Client for DCO v8.0 with custom CSS. For desktop client you can submit feature request.
(CID:108824766)
Posted: 2020-07-03 05:52 AM . Last Modified: 2023-10-31 10:47 PM
