Posted: 2020-07-03 09:25 AM . Last Modified: 2024-04-08 03:33 AM
Hi
What is the latest version for the "Appliance StruxureWare Data Center Expert" (AP9465).
I have to install one with version 7.2.7.25 and I would like to update it if possible.
I know the version 7.4.2 for "DCE Virtual".
Thanks for the support.
(CID:110010445)
Hi Fabio,
The VM has always been at the same version as that which is installed on the hardware platforms. Both are currently at 7.4.2. To obtain the latest version, you'll want to contact your local tech support. They can verify support contracts which is required for upgrade and they can provide the links.
Steve.
(CID:110010450)
Hi Fabio,
Steve.
(CID:110010450)
Posted: 2020-07-03 09:25 AM . Last Modified: 2023-10-22 01:29 AM
