Posted: 2020-07-04 08:07 PM . Last Modified: 2024-04-04 04:19 AM
Hi, how I should make requests to the server to get information by API methods. I do request like http://
(CID:132663915)
Manual as in what are the methods available?
Have a look on these links
(CID:132663929)
(CID:132663929)
Thank you for answer, but under the manual, I meant these links. So I want to know how to use this information? Please, write some examples of request using methods.
(CID:132663936)
With actual DCE, use software like SOAP UI to test.
Easiest to test is to getAllDevices under Device Service, as it does not require any parameter.
In SOAP UI, select new SOAP project, load in the path to Device Service.
Supply the DCE user name and password, at least read only access.
SOAP UI will then load all the methods, and provide you with sample
Supply authentication for the call
Run it, and you'll see the response
(CID:132663949)
Thank you. It helps me a lot
(CID:132663983)
Posted: 2020-07-04 08:08 PM . Last Modified: 2023-10-22 01:28 AM
