DCE upgrade on virtual envirnment
  • EcoStruxure IT forum
  • DCE upgrade on virtual envirnment
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 12:44 AM . Last Modified: ‎2024-04-05 04:28 AM
794
I have a client using a DCE V 7.2.6 installed in a virtual server, and needs to upgrade to DCE V 7.4.3
So, the upgrade process/steps in the virtual environment will be the same as in physical server? , or there will be any changes ?
7.2.6
(CID:126164914)
Hi Momen,
Process / steps to update a VM is the same as with a hardware server. You'll need to update incrementally and to get the links, you'll need to contact tech support and they'll need to validate support.
Steve
(CID:126164929)
Replies 6
Hi Momen,
Steve
(CID:126164929)
Hi Momen Samy,
In more detail you will be interested in reading Balaraman Jagadeesan answer in the topic , since in your case the upgrade process can be lengthy.
With respect.
(CID:126164944)
Posted: ‎2020-07-04 12:45 AM . Last Modified: ‎2024-04-05 04:28 AM
Hi Momen Samy,
You have successfully solved your question or not?
With respect.
(CID:126167542)
I have just made the upgrade process smoothly on the VM server.
Thanks.
(CID:126167926)
Hi Momen Samy,
Very thanks for the feedback.
(CID:126167980)
Posted: ‎2020-07-04 12:45 AM . Last Modified: ‎2023-10-22 01:28 AM
This is a heading
