DCE power logic
  • DCE power logic
129
72
Posted: ‎2020-07-05 05:57 PM . Last Modified: ‎2024-04-03 03:10 AM
1030
DCE power logic
Good Day,
i have never done this type of connection so please excuse me if i sound stupid, how can i connect a power logic PM700 to DCE? Can i use an RS485 to Ethernet converter? or is there a better or simpler way?
(CID:140713445)
Hi Terrence,
I believe your first instinct is correct. Assuming the meter only has 232 or 485 and no Modbus over tcp, you’ll need a Modbus serial to ip gateway. I believe the current one we suggest is the EGX150. You’ll then also need to hit the DDF link on the top of the page and request the proper DDF.
Steve.
(CID:140713466)
Hi Terrence,
Steve.
(CID:140713466)
Posted: ‎2020-07-05 05:57 PM . Last Modified: ‎2023-10-22 01:26 AM
