Posted: 2020-07-04 10:20 PM . Last Modified: 2024-04-04 03:23 AM
Hello! I have message "Cannot bind to LDAP server at "************" with supplied DN and password"
and
Bad authentication connecting to LDAP server ldap://vdc1.matfmc.ru:389/ as CN=Ларин Александр,OU=Отдел внедрения ИС,OU=Дирекция ИТ,DC=matfmc,DC=ru
So i would like to ask if cyrillic symbols supported in this parameters?
(CID:134023472)
DCE version 7.5.0, virtualized
(CID:134023474)
Hi Nikita,
I've heard of no issues with the character set you're using but I'll defer to anyone else that has used that in this application to verify.
As for the authentication (assuming the characters are supported), you may want to check out the following k-base:
http://www.apc.com/us/en/faqs/index?page=content&id=FA158395
It has a good amount of info on how this should be set up.
For instance, one tip notes that if there is a space in the name that you may want to enter it in quotes:
CN="Ларин Александр"
instead of
CN=Ларин Александр
Another issue could be protected users as noted in #6 on that document and we don't play well with them. You get an authentication error.
Steve
(CID:134023494)
Dear Nikita Koloskov,
Tell us, please, have you solved this problem or not?
With respect.
(CID:134026444)
We will try your advise soon...
(CID:134029014)
Ok, thanks for the feedback 😀.
(CID:134029018)
Posted: 2020-07-04 10:20 PM . Last Modified: 2023-10-22 01:23 AM
