DCE backup fails to mount
  • EcoStruxure IT forum
  • DCE backup fails to mount
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 09:51 AM . Last Modified: ‎2024-04-10 01:05 AM
1203
I would like your help on how to setup a windows share and or NFS to properly backup the DCE .
IS there any specific guide or examples on hot to setup this windows share on the laptop for the DCE to be able to save the backup?
(CID:93913100)
  • Data Center Operation
1203
HI, Jose!
There is nothing special.
First, you need a shared folder on your laptop and user, with rights to to write there.
Then, You need to connect your laptop to the DCE network and fill window's fields with Your's laptop IP-address, user name and password from step one. As Domain you can specify your's laptop name, and in "Share" field  - name of shared folder, as its displayed in Shared Folders view of System Management Window (without path to it). And choose type of backup.
After that you need to press "Test Mount" and if all be ok, "Finish" button will be active.
(CID:93913107)
Replies 4
1204
HI, Jose!
(CID:93913107)
And if the mount is not successful, please check the firewall and close it then have another try.
(CID:93913124)
Hi, I have tried this one, mount is successful only once and backup fails at 80% afterwards you can't mount the same share anymore, even when you create a new one on the same system. Do you have an idea how to resolve that?
(CID:93914152)
Posted: ‎2020-07-02 09:52 AM . Last Modified: ‎2023-10-31 10:25 PM
