DCE and DCO log level
  • DCE and DCO log level
127
65
Posted: ‎2020-07-03 12:25 PM . Last Modified: ‎2024-04-08 01:57 AM
1131
Hi team,
Is it possible to change log level (set debug level for example) to DCE and DCO application servers?
Like it is possible in NetBotz.
(CID:110793621)
  • Data Center Operation
1131
Hi Dmitry Togushev,
DCE does not support sending to a Syslog server at the moment. There is an enhancement request in the system to add this feature in a future release, but I cannot say if or when that will happen.
However, as you probably already know, the devices (APC & NetBotz) can be configured to send to Syslog.
Maybe someone else can provide information about DCO and Syslog support.
Regards
(CID:110793870)
Replies 7
1132
Hi Dmitry Togushev,
Regards
(CID:110793870)
Hi John,
DCE stores its log to /data/logs/nbc/nbc.xml. The log is accessible via web interface. It is good.
The question is:
Is it possible to change log level (for example debag or error-only) of this log.
In NetBots Advance View it is possible.
(CID:111415204)
Hi Dmitry,
The only option on the DCE web interface at the moment would be to change the Category in the Event Log, but this is probably not the same as changing the log level for the nbc logs. I don't think there is any other way to change the log level until Syslog support is added in a future version.
Regards
(CID:111415428)
Hi John, thank you for you answer.
Is any road map or something like it available to understand a time when  'it will be added in a future version' ?
(CID:111937919)
Hi Dmitry,
I know that it is on the roadmap for a future release, but I cannot say when it will be added.
Maybe someone else from product management can comment on this.
Regards
(CID:111938596)
Posted: ‎2020-07-03 12:26 PM . Last Modified: ‎2024-04-08 01:57 AM
Hi Dmitry Togushev, thanks for posting. Lets see who can be of assistance here. @community any ideas?
Kind regards Ditte
(CID:110793880)
Posted: ‎2020-07-03 12:26 PM . Last Modified: ‎2023-10-22 01:22 AM
