DCE and DCO VM specifications
  • DCE and DCO VM specifications
129
72
Posted: ‎2020-07-04 04:04 AM . Last Modified: ‎2024-04-05 03:07 AM
1089
Hi Team,
Question for both DCE and DCO running in a Virtual environment
  1. I think there is a typo in the DCE max VM specifications:
    http://sxwhelpcenter.ecostruxureit.com/display/public/UADCE725/Minimum+and+maximum+StruxureWare+Data...
    Should it be the other way around: 4xCPU and 16GB RAM ?
  2. For DCO is there a specific link between the CPU cores and the amount of RAM?
    My customer would like to give DCO 8xCPUs and 128GB RAM as this is his standard VM package...any issues with that size?
(CID:128065772)
  • Data Center Operation
1089
Hi Lukasz,
1- You are right, it seems to be mis-typed, the system recommendation (for DCE) for up to 4025 device nodes should be 4 GB RAM and 4 CPUs. (corrected now)
2- For DCO, having 8 CPU cores and 128 GB RAM would be just fine.
The minimum recommendation for a setup with 8 CPUs, would be at least 32 GB RAM (so having more RAM would not cause any problem).
Kind regards
(CID:128066145)
1090
Hi Lukasz,
Kind regards
(CID:128066145)
Posted: ‎2020-07-04 04:04 AM . Last Modified: ‎2024-04-05 03:06 AM
Thank you kindly Jef,
Not always more is better and supported so just wanted to make sure DCO OS layer won't complain about too much RAM 😀
(CID:128066571)
Posted: ‎2020-07-04 04:04 AM . Last Modified: ‎2023-10-22 01:22 AM
