Posted: 2020-07-02 03:18 PM . Last Modified: 2024-04-09 03:12 AM
Is it possible to create, then share (or publish) dashboards for other users (or as a default dashboard for new users)?
Racking my brain here, but I cannot find any good documentation on management of DCE Web client.
I just want a standard dashboard for all users at logon, and a few different dashboards we can use on Wallboard displays in our NOC.
Thanks in advance!
(CID:102236215)
Hi Chris,
The DCE client dashboards are tied to the specific user. If you log in as user A on your computer and then as user A on another, you can see user A's dashboards. If you log in as user B however, you can not see user A's dashboards. This is by design as different users have access to different devices but that access was not trickling down to the sensors. I guess it was easier to do this than it would be to verify the user has access to the data in a specific graph or other gadget.
Steve
(CID:102236219)
Hi Chris,
Steve
(CID:102236219)
Thanks for your quick response. While i understand the reasoning behind this, I am disappointed that this function is lacking. As an administrator, I can control user access levels in DCE; so logically, i assumed I would be able to build basic views based on that access.
(CID:102236403)
Hi Chris, I know they're looking into this for future releases but I have no info as to when that may be. Steve
(CID:102236405)
This would be a nice feature to get, since I haven't had much luck getting the Portal to work the way I want and generally the DCE dashboard has better graphs for sensors.
(CID:102236227)
Posted: 2020-07-02 03:19 PM . Last Modified: 2023-10-31 10:45 PM
