DCE VM convert thin to thick provisoning
  • DCE VM convert thin to thick provisoning
129
72
Posted: ‎2020-07-02 02:26 PM . Last Modified: ‎2024-04-09 04:12 AM
903
Hi All,
We need to convert a DCE (7.2.4) VM from thin to thick storage provisioning due to poor server performance.
Is it possible to change this without requiring a server rebuild?
(I assume that DCE can be gracefully shutdown, provisioning changed to thick, additional hard disks added to increase capacity)
(CID:99157517)
Posted: ‎2020-07-02 02:27 PM . Last Modified: ‎2024-04-09 04:12 AM
903
David,
To my knowledge, you shouldn't have any issues changing hard drive provisions  from thin to thick. I would recommend that a full backup or a snapshot of the VM prior to changing hard disk type to revert to in case a problem occurs.
Thank You
Victor
(CID:99157626)
Replies 4
Hi David, thank you for posting. I'll see who can be of help here. @community any thoughts?
(CID:99157603)
904
David,
Thank You
Victor
(CID:99157626)
Thanks Victor
(CID:99157681)
Posted: ‎2020-07-02 02:27 PM . Last Modified: ‎2023-10-31 10:45 PM
