DCE VM Trial license states 25 nodes but errors at 5
  • DCE VM Trial license states 25 nodes but errors at 5
129
72
Posted: ‎2020-07-04 01:46 AM . Last Modified: ‎2024-04-05 04:01 AM
986
I finally get private network working and start adding devices. License states 25 nodes but will only allow 5.  The whole reason for spending hours and hours configuring was so we could have complete view of our DC which 25 nodes would cover. Is there any way to add 25 nodes as license states??
(CID:126174223)
986
Dear Jeff,
The Virtual Machine or VM version shows this same 25 node license key in the user interface however until activated, will only allow 5 nodes to be added to the system.
Resolution:
This is by design. It was done so APC did not need to add a 5 node key to just this one version.  Once activated, the rest of the nodes can be used.
To know more AP94VMACT, click here.
I hope this helps.
Bala
(CID:126174230)
987
Dear Jeff,
Resolution:
I hope this helps.
Bala
(CID:126174230)
Just an FYI, k-base FA176217 makes a note of this as well.
(CID:126174394)
Posted: ‎2020-07-04 01:46 AM . Last Modified: ‎2023-10-22 01:21 AM
