Posted: 2020-07-03 10:17 PM . Last Modified: 2024-04-07 11:08 PM
Hello, I am having problems to query the server using snmp.
I need to check the server that alarms have active alarms.
I saw that there is a OID that can be consulted to know the same.
It did not work and on the server I have snmp access enabled.
Who could help me?
Thank you
regards
(CID:124520944)
unfortunately the DCE snmp agent is unable to report any DCE application related data. Instead it is used for monitoring the linux OS that DCE runs on, such as uptime, load, memory, etc.
If you are looking to externally monitor the DCE server for alarms and sensors, you could use the web service api instead or just the servers web page. Additional documentation can be found here
https://dcimsupport.apc.com/display/public/DCIMDEVELOPER/StruxureWare+Data+Center+Expert+Web+Service...
(CID:124520950)
(CID:124520950)
thank you, now I will try with the suggested.
regards
(CID:124520955)
Posted: 2020-07-03 10:18 PM . Last Modified: 2023-10-22 01:19 AM
