Posted: 2020-07-03 09:36 AM . Last Modified: 2024-04-08 03:29 AM
If i receive DCE Restore ISO, for AP9465 (A- customer). What can i restore it on AP9470 (B or C customers)?
(CID:110012425)
Hi Shahzad,
Yes you can use the same ISO for AP9470, If you do not have the current version, you may need to contact your local tech support to obtain the download link. If you plan to re-import a previous backup, be sure that you have not only made a backup but that you also restore the DCE server to the same version as importing a backup will not work from a different version.
(CID:110012431)
Hi, I am stuck more then 3 hours at following stage during restore V7.2.2. Can anyone help, where is problem.
(CID:110013669)
Hi,I have encountered the same problem ,is your problem solved?
(CID:111414899)
Posted: 2020-07-03 09:36 AM . Last Modified: 2023-10-22 01:19 AM
