Posted: 2020-07-03 02:40 PM . Last Modified: 2024-04-08 01:14 AM
Hi
We are using DCE 7.4.1 and today our security team come up with a security issue as after scan they come up with a result that
Port 443 has;
SSLv2 PROTOCOL IS DISABLED
SSLv3 PROTOCOL IS DISABLED
TLSv1 PROTOCOL IS ENABLED
TLSv1.1 PROTOCOL IS ENABLED
TLSv1.2 PROTOCOL IS ENABLED
They want that TLS 1.0 and 1.1 need to be disabled and TLS 1.2 needs to be enabled.
I could not find any option to disable TLS 1.0 and 1.1 in DCE client software.
How can we disable these?
Will DCE continue to function with only TLS 1.2 enabled?
Kindly help me to solve this issue.
Regards
Imran
(CID:116362211)
Hi imran.haq,
Such question was already asked quite recently: watch the answer here .
With best regards.
(CID:116362224)
Posted: 2020-07-03 02:41 PM . Last Modified: 2024-04-08 01:14 AM
Thanks Spezialist
(CID:116362235)
Posted: 2020-07-03 02:41 PM . Last Modified: 2023-10-22 01:18 AM
