Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
DCE (Panduit P36F13M & Oracle RMII PDU15KVA 3HV)
  • EcoStruxure IT forum
  • DCE (Panduit P36F13M & Oracle RMII PDU15KVA 3HV)
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 05:54 PM . Last Modified: ‎2024-04-03 03:11 AM
1102
I'm trying to make a current (amps) threshold for a panduit and for an oracle 3phase pdu's but the DCE shows only one of the three phase.
Does anyone know what is this about? what can i do?
(CID:140713131)
Replies 6
Hi Grigorios,
If you feel there should be 3 separate current amp phase sensors then there is likely one of 2 issues. Either the device definition file (DDF) does not have the information for these values or the device itself is not reporting them. The first thing I would suggest is to poll the device for these values. Be it Modbus or SNMP, DCE will delete a sensor if the polled value does not properly respond. If you find that the device is responding correctly, I would suggest using the DDF menu at the top of this page and requesting a modification of the DDF.
Steve
(CID:140713196)
Thank you for your respond.
As you can see both pdus have 3 phase sensors. (if this is what you mean)
(CID:140713261)
Dear Grigorios Kousidis,
Tell us, please, did you solve your problem or not?
With respect.
(CID:141269215)
1103
Not yet,
we were upgrading our DCE versions.
I will send a device walk to the "device request"
(CID:141271943)
Ok, anyway thanks for the feedback.
(CID:141271953)
Posted: ‎2020-07-05 05:55 PM . Last Modified: ‎2023-10-22 01:18 AM
