DCE Memory configuration
  • DCE Memory configuration
129
72
Data Center Expert
minrusi
Ensign minrusi
Ensign
Posted: ‎2025-03-05 05:56 AM
1206
Recently upgraded DCE to 8.2.0. Moved to new VM with 16GB RAM of memory and 16CPUs.
But in the logs found interesting line:
"Server configured to use a maximum of 7.9 GB of memory with 16 CPUs."
How to allocate all available memory to DCE?
Our setup is quite big, with more than 2000 devices, and would like to use all available resources.
Admiral
Posted: ‎2025-03-10 06:30 AM
1152
Hello @minrusi,
That amount of RAM is likely what the application running on the server is configured specifically to use.  The total utilized RAM should be more than that with OS functions also consuming some of the other assigned RAM.
If you check the following URL, ensuring to replace IP_Address with the IP address of your server, you can see the CPU and RAM information: https://IP_ADDRESS/nbc/compress/support/hwinfo
Cory
Admiral
1153
Hello @minrusi,
Cory
minrusi
Ensign minrusi
Ensign
Posted: ‎2025-03-13 12:11 AM . Last Modified: ‎2025-03-13 12:13 AM
In response to Cory_McDonald
Checked memory info, seems all 16GB of ram are available, probably you are right, that 7.9 GB of allocated memory is for the DCE application, other memory is allocated for other OS functions:
Memory Info
MemTotal:       16136144 kB
MemFree:         7213456 kB
MemAvailable:   10948860 kB
Buffers:          368688 kB
Cached:          3602524 kB
SwapCached:            0 kB
Active:          3288032 kB
Inactive:        4509340 kB
Active(anon):      40816 kB
Inactive(anon):  3842024 kB
Active(file):    3247216 kB
Inactive(file):   667316 kB
Unevictable:       12396 kB
Mlocked:            9916 kB
SwapTotal:       2097148 kB
SwapFree:        2097148 kB
Dirty:             10172 kB
Writeback:             0 kB
AnonPages:       3836904 kB
Mapped:           200952 kB
Shmem:             53284 kB
KReclaimable:     207688 kB
Slab:             991688 kB
SReclaimable:     207688 kB
SUnreclaim:       784000 kB
KernelStack:       10984 kB
PageTables:        19856 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:    10165220 kB
Committed_AS:    4924200 kB
VmallocTotal:   34359738367 kB
VmallocUsed:       62052 kB
VmallocChunk:          0 kB
Percpu:             9984 kB
HardwareCorrupted:     0 kB
AnonHugePages:   3588096 kB
ShmemHugePages:        0 kB
ShmemPmdMapped:        0 kB
FileHugePages:         0 kB
FilePmdMapped:         0 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
Hugetlb:               0 kB
DirectMap4k:      200576 kB
DirectMap2M:    10285056 kB
DirectMap1G:     8388608 kB
