Posted: 2020-07-02 04:04 PM . Last Modified: 2024-04-09 02:56 AM
Dear All,
Is it possible to install DCE on physical server.
Emre
(CID:103584445)
Dear Emre,
As far as I know, DCE Virtual Appliance is currently supported only on VMware Server ESXi Host 4.1.0 +
The StruxureWare Data Center Expert Software is available as a virtual appliance,
supported on VMware ESXi 4.1.0 or later versions.
You can download DCE Demo OVA file from the below link:
http://updates.apc.com/isxc/surveys/vm/7.2.7/survey.cfm
StruxureWare Data Center Expert Virtual Appliance.pdf
I hope this helps.
Bala
(CID:103584449)
Hi Emrekoca,
Just to add to Bala's response, if you're not referring to installing the VM on a physical server but thinking of installing the regular DCE on a non-APC server, that is unsupported. You will likely not have drivers to properly work. Check out k-base FA239972.
Steve
(CID:103584528)
Posted: 2020-07-02 04:04 PM . Last Modified: 2023-10-31 10:27 PM
