DCE 7.8.0 fail GNU GRU
  • DCE 7.8.0 fail GNU GRU
127
65
masolans
Ensign masolans
Ensign
Posted: ‎2024-09-26 02:55 AM
604
The DCE sudanly hang, and can't acces it, after restart it appear GRUB>
How can solve it?
Admiral
Posted: ‎2024-09-26 08:12 AM
583
Hello @masolans,
Usually if you are at a GRUB prompt on reboot, the system has completely crashed and a backup/restore is the quickest method of recovery.  You can contact support if you would like to try to investigate the system and determine what happened, which may or may not be possible depending on the failure.
Below are steps that you can take to restore your system if you have a valid backup:
  1. Ensure that there are no hardware errors on the server itself.
  2. Download the ISO image for the same DCE version that the backup was created on.  This can be downloaded from the EcoStruxure IT Entitlements Portal.  If you do not have access, please reach out to technical support for contract verification and access to be provided.
  3. Build the ISO image onto a USB using the dedicated utility found on the Help Center or download page.
  4. Restore the server using the USB key.
  5. Go through the base setup again of passwords and network settings using the console: https://www.apc.com/us/en/faqs/FA234266/
  6. Restore a backup to the appliance.
Kind Regards,
Cory
masolans
Ensign masolans
Ensign
Posted: ‎2024-09-26 08:39 AM
In response to Cory_McDonald
As you say may be any hardware issue, i think may be safe contact with support before make a recovery. If There are a hardware issue a new server may be necesary
