DCE-7.7: Russian letters "ั" and "ั" are displayed incorrectly in the web GUI.
Showing results forย
Did you mean:ย
  • DCE-7.7: Russian letters "ั" and "ั" are displayed incorrectly in the web GUI.
129
72
Posted: โ€Ž2020-07-05 08:44 PM . Last Modified: โ€Ž2024-04-03 01:06 AM
1328
Dear support,
After installing the new version of DCE-7.7, I found a bug: the russian letters "ั" and "ั" are displayed incorrectly in the web-GUI:
I hope this bug will be fixed ๐Ÿ˜€.
Very thanks for the support.
(CID:147195989)
  • bug
Replies 7
Hello, have you asked your local techsupport or opened a ticket @ Schneider Customer Care? If not yet, please apply to the Moscow one at ru.ccc@schneider-electric.com   and we will help you to escalate your issue. Thanks.
(CID:147201911)
Dear Andrey Ivashov,
Thanks for the tip ๐Ÿ˜€.
Support case number: 61535898.
(CID:147202121)
I inform you again: in the new release of DCE-7.7.1, which took place last week, there is a similar bug:
According to your recommendation, I created the corresponding support case  # 61535898 of August 6th. But so far I have not received a single answer.
Tell me please - is this normal?..
(CID:148343689)
Hi spezialist, thanks for posting!
I'll try to follow up on this.
Kind regards,
Stine
(CID:148343692)
1328
Hi spezialist,
Iโ€™ll follow up on this with engineering. Thanks for pointing it out.
Best,
Jackie
(CID:148343746)
Ok, very thanks for the support.
(CID:148343794)
Posted: โ€Ž2020-07-05 08:44 PM . Last Modified: โ€Ž2023-10-22 01:13 AM
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
