DCE 7.6 errors starting desktop client
  • DCE 7.6 errors starting desktop client
126
65
Posted: ‎2020-07-05 04:54 PM . Last Modified: ‎2024-04-03 04:20 AM
903
Hello
When starting DCE desktop client I'm getting an error that version is invalid. However I'm using the client, that is downloaded from the DCE web portal.
I've tried reinstalling client, but without any luck
(CID:139692874)
  • bug
Figured out. Issue was with timeout to OLD LDAP server, where my current user had same login name.
In logs found exceptions
Error connecting to LDAP server <a href="ldap://10.250.0.10:389/:javax.naming.CommunicationException" target="_blank" rel="nofollow noopener noreferrer">ldap://1xxx.xxx.xxx.xxx.:389/:javax.naming.CommunicationException</a>: <a href="ldap://10.250.0.10:389/:javax.naming.CommunicationException" target="_blank" rel="nofollow noopener noreferrer">xxx.xxx.xxx.xxx</a>:389 [Root exception is <a href="http://java.net" target="_blank" rel="nofollow noopener noreferrer">java.net</a>.SocketTimeoutException: connect timed out]
After deleting the Authentication server, everything is working fine.
(CID:139692917)
If I select Yes on prompt it opens the pag ewith URL http://127.0.0.1:0/
(CID:140217472)
(CID:139692917)
Posted: ‎2020-07-05 04:54 PM . Last Modified: ‎2023-10-22 01:13 AM
