DCE 7.5 Server Access Settings Error
  • DCE 7.5 Server Access Settings Error
129
72
Posted: ‎2020-07-04 01:51 PM . Last Modified: ‎2024-04-05 02:49 AM
1012
After upgrading to DCE 7.5 I now cannot access the Server Access settings under Server Administration Settings. I get the error message below.
Any ideas?
DCE Error.txt
(CID:128752378)
1012
Hi Richard,
I had the same problem after enabling port 80 via the Server Access page in version 7.5.0, technical support fixed this via a WebEx session,
In my case it occurred because I had port 80 disabled before updating to 7.5.0, after the update I enabled port 80. The result was the same as you have.
I’d recommend raising a support call.
Dom
(CID:128752601)
Replies 4
1013
Hi Richard,
Dom
(CID:128752601)
Posted: ‎2020-07-04 01:52 PM . Last Modified: ‎2024-04-05 02:49 AM
Hi Dom,
thanks for the tip. I did have port 80 disabled prior to the upgrade so I will give support a call to try and rectify.
Richard
(CID:128753926)
Schneider Technical Support attended site
Logged into the console as root
enabled Listen 80 in the Netbotz.conf file
Once done the issue was resolved and I could then disable port 80 through the client and all was back to normal.
(CID:128757425)
Posted: ‎2020-07-04 01:52 PM . Last Modified: ‎2023-10-22 01:11 AM
